Hey this is my first time building a gaming PC and was was wondering if there was anything wrong with the specs
CPU: AMD Ryzen 9 3900X with Wraith Prism
GPU: MSI GeForce RTX 2080 Ti Gaming X Trio 11GB
AIO: NZXT Kraken X53 240mm AIO Liquid CPU Cooler
RAM: Team T-Force Dark Z 16GB (2x8GB) 3600MHz CL18 DDR4 Grey (I do plan on getting two more sticks to put me up to 32GB)
MOTHERBOARD: ASUS ROG Strix B550-F Gaming Wi-Fi Motherboard
HARD DRIVE: Western Digital WD Blue 4TB WD40EZRZ 3.5in Hard Drive
SSD: ADATA XPG SX8100 M.2 NVMe SSD 256GB
POWER: Corsair HX1000 Platinum 1000W Power Supply
any information on if massive bottleneck issues may occur will also me much appreciated
Ps I don't know if this matters but I plan on playing triple A titles like cyberpunk 2077 on this
https://linustechtips.com/topic/1218347-my-first-build/
Don't buy a flagship PC a few months before new stuff is launched. It's a horrible idea.
I'd also get a much larger SSD.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1218347-my-first-build/#findComment-13789822
First off, if you can wait a few months, do. Buying very high end hardware now is not what I would do as the next generation is coming out in a few months and should be 20-30% faster (prices currently unknown).
You might want more ssd storage. I don’t know anything about b550 boards so I can’t comment on that. You might want to get cl16 ram instead of cl18. It shouldn’t be that much more expensive. Aside from that, looks good.
What case are you going to be using?
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
https://linustechtips.com/topic/1218347-my-first-build/#findComment-13789823
Isn't 4000 series to be announced in literally 2 days? Or am I mistaken.
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/1218347-my-first-build/#findComment-13789834
believe its due in september, but not positive
CPU: AMD 3600X
GPU: Nvidia 3070 (planned)
motherboard: MSI B500-A PRO
memory: G Skill Ripjaws V 2x8 GB 3600Mhz CL16
PSU: EVGA B3 650@
Case: NZXT H510
wireless network adapter: intel ax200
https://linustechtips.com/topic/1218347-my-first-build/#findComment-13789841
23 minutes ago, rapidkillerx said:
id get a bigger (1tb) nvme ssd, other than that pretty solid
23 minutes ago, Matty2048 said:
yeah all looks good no major issues maybe more ssd
I was thinking about more SSD but I didn't think it was relevant because I was just going to use it for my os but seeing as though a few people have said get more SSD I feel like there is something I'm not understanding
https://linustechtips.com/topic/1218347-my-first-build/#findComment-13789891
you should also put your most played games and other used programs on it
CPU: AMD 3600X
PSU: EVGA B3 650@
Case: NZXT H510
https://linustechtips.com/topic/1218347-my-first-build/#findComment-13789912
It’s good to have your most used programs and games on an ssd to get much better boot times.
PSU Tier List
SSD Tier List
PARROT GANG
https://linustechtips.com/topic/1218347-my-first-build/#findComment-13789915
1 hour ago, Toilet baby said:
And the power supply definitely is overkill but I plan on adding to this as time goes on and wanted to have ample power to satisfy my pc’s needs
A 750w PSU is enough unless you have a dumb setup like a oced 10980xe and dual oced 2080tis.
https://linustechtips.com/topic/1218347-my-first-build/#findComment-13790092
