Need help figuring out what's compatible with my motherboard
Solved by homeap5,
M.2 don't disable your SATA ports. It may disable one or two on some motherboards in some conditions, but for sure not all. Read manual.
Don't worry about pcie slots - you have more than one and for sure you'll not buy pcie slot m2. Even if - you'll be fine.
Featured Topics
Mahbub ·
Posted in Programming0 -
Johnny Fehr ·
Posted in New Builds and Planning3 -
1
1
Nexxus ·
Posted in Programs, Apps and Websites3 -
5
PSP. ·
4
kennethk ·
Posted in Troubleshooting0 -
bsforyt727 ·
Posted in General Discussion4
