Dvi Only GPU Outputs an Audio Signal. HOW??
Solved by Sakkura,
Just now, iunkeren said:Does that mean there are some exception to dvi port and dvi to hdmi converter?
Interesting
I couldn't find this info on google
Wikipedia describes it.
https://en.wikipedia.org/wiki/Digital_Visual_Interface#DVI_and_HDMI_compatibility
QuoteSome DVI-D sources use non-standard extensions to output HDMI signals including audio (e.g. ATI 3000-series and NVIDIA GTX 200-series).[9] Some multimedia displays use a DVI to HDMI adapter to input the HDMI signal with audio. Exact capabilities vary by video card specifications.
