help me choose a soundcard
dreamcast4599
im not happy with the onboard audio on my CH7 hero seems like every time i play a youtube video or watch a movie or listen to music or even play a game the audio is either too loud or too quiet. what sound card do you recommend also if it matters my mobo has no loudness equilization, please dont tell me to mess with the settings i just want a good pcie sound card
How'd you get on with the fans...?  :)
I frequently edit any posts you may quote; please check for anything I 'may' have added.
Did you test boot it, before you built in into the case?
WHY NOT...?!
Sound blaster AE-9. The one I have but it is a little bit expensive coming around 300 euros. Another one is the ae-7 which is also great but a little cheaper at like 200+ euros
PM or DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
Beyerdynamic Tygr 300 R w/ Dekoni Velour as daily driver
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Keyboard > SteelSeries Apex Pro
Mouse > Steelseries Aerox 3 wireless
Mousepad > Pulsar ParaSpeed XXL
VR > Valve index kit
Read this post if you want a "gaming" headset ;)
With the sound blaster ae-7 or ae-9 you really need the software so don't forget to download it if you get one ;)
AKG P420 Mic
Other peripherals
to expensive for me lol
2 minutes ago, dreamcast4599 said:
@Eighjan i got it all sorted out managed to find some splitters for my fan headers
Maybe the soundblaster Z?
AKG P420 Mic
Other peripherals
SoundBlaster Z or Zx may be more affordable...
WHY NOT...?!
Things being too loud or quiet is not a reason to get a sound card. Use the inbuilt mixer in windows to set your programs so they play at roughly the same volume (if audio controls aren't available in the program itself. Different Youtubers upload their videos at differing loudnesses and unfortunately compression in YT can't always fix it so there's not much you can to to solve that, for me the best thing I found was a physical volume control, as in, I have a knob I use to control volume to my speakers and I find that it's just second nature to be using it when I find something too loud or quiet.
Again, while the other responses on here are indeed suggesting sound cards, getting one won't solve anything for you.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
what mixer
6 minutes ago, dreamcast4599 said:
what mixer
Right click the speaker icon on your taskbar (next to the time and date indicator)
Open Volume Mixer
You can control the volume of each program separately, every game, every program that produces audio at all will appear here when you open it and the level you choose is where it stays until you decide to change it again.
@rice guru
What's your current speakers/headphones?
PC Audio Setup = Beyerdynamic DT 770 pro 80 ohm and Sennheiser pc37x (also for xbox) hooked up to Schiit Fulla 3
generic 20$ sound bar from biglots
I would say the problem is either a setting in the software or maybe the volume setting on the soundbar. I would definitely recommend looking into settings in software and on the soundbar before buying a new sound card. I'm almost certain your current onboard audio isn't the problem. It could also be the volume of the different videos is just mastered differently. Some youtube videos are just loud or just quiet
