3 Pin fans on a 4 pin header?
mitchell2380
Just ordered a new motherboard but it only has 4 pin pwm fan headers and my rear case fan is a 3 pin. Can I use it on a 4 pin header if so how?
should be fine, i have 2 3 pin fans in 4 pin headers currently. as far as how, the headers have a groove that makes it only fit one way, fan should have the same grove and plug right in. headers are made with using a 3pin cable in mind.
#fullsend
The 4th pin is just for PWM to slow the fan down. Just make sure to line up the notch so it fits nicely.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Fedora 38 x86_64
Secondary: AMD Ryzen 5 5600G, 16 GB 2667 MHz DDR4, Fedora 38 x86_64
Server: AMD Athlon PRO 3125GE, 32 GB 2667 MHz DDR4 ECC, TrueNAS Core 13.0-U5.1
Home Laptop: Intel Core i5-L16G7, 8 GB 4267 MHz LPDDR4x, Windows 11 Home 22H2 x86_64
Work Laptop: Intel Core i7-10510U, NVIDIA Quadro P520, 8 GB 2667 MHz DDR4, Windows 10 Pro 22H2 x86_64
Yes, they'll run normally, it's just that you won't be using the PWM functionality.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
You connect it like you would a 4-pin fan. The latch fits 3 & 4 pin fans. The difference would be weather fan control is done via PWM or TACH.
