What does that even mean?
FPS is how many frames per second your computer can put out per second,
HZ is how many pictures the monitor can show per second.
So if your computer gives out 145FPS, but the monitor is 75hz, you will just see 75 pictures per second.
I only see your reply if you @ me.
https://linustechtips.com/topic/1214148-fps-and-hz/#findComment-13755805
2 minutes ago, xyan3 said:
correct me if im wrong is it true that if my monitor is 75hz it can only run 75 fps max on all games and if my com is 144hz it can only run 144fps on all games
If it's 75Hz, the display will refresh 75 times a second, however you can still run at higher fps, and this can be beneficial in giving a smoother experience
PC
Ryzen 5 2600 Stock
Sapphire Nitro+ Special Edition Radeon RX580 8GB (Would Recommend)
Gigabyte B450M DS3H (Don't recommend)
Hyper 212 RGB Black Edition
Corsair Vengeance LPX 2x8GB DDR4 3000MHz CL15
Phanteks P300 (Would Recommend)
Kingston A400 240GB SSD
Seagate BarraCuda 1TB HDD
Corsair CX550M 550W  80+ Bronze
Deepcool FH-10 Fan Hub
3x BeQuiet Pure Wings 2
https://uk.pcpartpicker.com/user/marmour/saved/QTY3ZL
Peripherals
LG 24MK400H
Logitech G413 Carbon
Logitech G305 (AAA Adaptor - 10g reduction) (Would recommend)
Logitech Z150
HyperX Cloud II (Would recommend)
Moto G5 Plus (Webcam)
Phone
Pixel 3A XL (Would recommend)
*Useful Link* PSU Tier List: https://linustechtips.com/main/topic/1116640-psucultists-psu-tier-list/
https://linustechtips.com/topic/1214148-fps-and-hz/#findComment-13755806
Nope. Your computer can send out how ever much (or little) fps it wants, regardless of what kind of monitor your have.
Of course if you have a 75Hz monitor, you can only see 75 frames per second.
Having more fps than Hz can be beneficial in terms of frametimes:
Things like VSYNC limit your fps to Hz, but simply hold back frames to sync up.
Gsync/Freesync will make it so your Hz will match the fps your computer sends out, but these often only work in certain ranges (freesync usually having a smaller range).
https://linustechtips.com/topic/1214148-fps-and-hz/#findComment-13755816
your computer can run as high framerate as it can regardless of what sort of display is attached, but its not because those frames are generated, that those frames are displayed.
essentially (technically wrong, but easier to explain this way) your GPU cranks out frames, and puts whatever it outputs into a buffer. it does this at the framerate your computer can do it at, depending on hardware and configuration. this is listed in "FPS" (Frames generated Per Second)
your display refreshes an amount of times per second (expressed in Hz), and on each refresh it grabs whatever is in the output buffer, and displays that information, which then remains on screen until the next refresh.
so in essence, you display "display refresh rate" number of frames per second, wether your computer generates more or less than that.
where the 'details' go is, that when you have a higher framerate being cranked out by the GPU, the information your display grabs to put on screen is newer. for example if your game runs at 60FPS, each frame will be 16ms old before it is replaced, but even on a 60Hz display, if your game runs at 240FPS, the information your 60Hz display shows is only 4ms old. this essentially means (mostly for quick-action shooter games) that your response time is lower, giving you a better reaction time, despite there is no actual difference in screen refresh rate.
thar said, this last section is very.. very small difference.
https://linustechtips.com/topic/1214148-fps-and-hz/#findComment-13755831
