I need help getting my PC to POST.
Solved by ubuntu-guru,
If I'm not mistaken, no post code / beep means it is either power supply, motherboard, or CPU. I've had a few do this and it's always narrowed down to those three. So you'll have to check the basics.
Make sure the motherboard is properly mounted, screws aren't over-tight, maybe try reseating the CPU, and even apply some new thermal compound if you have some. The power supply you can't really do a bunch to other than attempting to reconnect the cables to the motherboard and see if somehow something is loose or not making proper connection.
