Hi,
I wonder if I'm way too crazy to think of using oil instead of distilled water for liquid cooling. I remember substation use oil to cool down the transformer.
Yeah, we might need to modify the pump because of the higher viscosity of the liquid, but... Maybe this will solve lots of problem that normal water liquid cooling has, such as corrosion and gunk build up.
I don't know, but hey, Linus Tech Tips, maybe you can experiment if my crazy theory makes sense?
Regards,
Chiyawa
I have ASD (Autism Spectrum Disorder). More info: https://en.wikipedia.org/wiki/Autism_spectrum
I apologies if my comments or post offends you in any way, or if my rage got a little too far. I'll try my best to make my post as non-offensive as much as possible.
https://linustechtips.com/topic/1209929-using-oil-as-liquid-cooling/
Been done, tested, and it doesn't work
Distilled water is much much much much cheaper and less corrosive
For the same value as oil, you can use liquid compounds which are much more thermally conductive and are not corrosive
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
Hmm... Can you maybe point me to this article? I haven't come across any thing related to liquid cooling using oil.
2 minutes ago, lewdicrous said:
Isn't this mainly due to the oil used not being electrically conductive?
Also, water is more thermally conductive when compared to oil.
Yeah. I mean, in case of leaks, we don't have to worry our electronics being short circuit.
Oil works as a coolant in large systems with heavy torque loads, like transmissions, differentials, etc.  But oil doesn't remove heat like water or other liquids, so it's not as effective on sensitive items.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
I mean, oil is a broad term.
Motor oil? Mineral Oil?
The latter has been done plenty of times to cool PC's, with very good results. However, mineral oil does nasty things to plastics sometimes. I believe Linus had an issue where after he disassembled his old mineral oil PC the DIMM slots on the motherboard broke apart.
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
Your pump will thank you for not using oil...  The flow rate and effort to pump it would kill most pump heads.  All I use is distilled water, biocide, and an anti corrosive...  No dies or funky shimmering premix (They clog up micro fins).  I can also see what is going on in my loop as far as any growth or discoloration (Use non plasticiser tubing).  The biggest thing is maintenance...  Once a year drain, clean, and rebuild.  Good time to upgrade anything you want as well!
You have to keep in mind the trade-off in thermal capacity/conductivity.
Without going down the extreme cooling routes (LN2, dry ice + isopropyl alcohol, etc.) I think water is the best you can get, imo at least. If, however, you're referring to extreme cases (extremely high/low temps.), then there are better fluids like actual coolants, instead of pure water, but this introduces problems of its own.
This as well as being really hard to clean; they kept the parts that they used in their mineral oil build in a bucket for a while and they still had oil residues when they used them after storage.
You won’t have an issue with distilled water if it leaks either. Unless it’s been in there for a year.
System shouldn’t be leaking if you have a system that has oil in it.
The oil used here isn't primarily for cooling; it's used to prevent electric arcs between conductors because oil has a higher breakdown voltage than air. (because voltages in substations are very high) Actually, modern substations don't use oil, but instead rely on some gas I can't remember the name of.
The easiest two disqualifiers for oil/glycol are:
Thermal conductivity is a non issue, no one builds a loop to leak all over.
Leaks are not common and only happen when you mess up the build or something breaks.
