https://linustechtips.com/topic/1208919-is-this-going-to-work/
3 minutes ago, Intelamd said:
Not out of the box for ryzen 3000 on b 450 you‘ll need to perform a bios update
also you can get Windows a lot cheaper
Hi
hi
https://linustechtips.com/topic/1208919-is-this-going-to-work/#findComment-13714077
Wherever you get the motherboard from, try calling ahead of ordering to see if they can give you some assurance - it may even be worth a few extra currency to get the CPU from them as well & ask if they'll verify that the BIOS version does support Zen 2/Ryzen 3xxx, prior to shipping.
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1208919-is-this-going-to-work/#findComment-13714081
Do i need hdmi cables or extra storage bec the windows is free ,well in my area and the seller already updated the bios
https://linustechtips.com/topic/1208919-is-this-going-to-work/#findComment-13714087
8 minutes ago, Intelamd said:
I mean, just looking at that case, how does the air get into the case when the case is basically glass with no visible vents?
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1208919-is-this-going-to-work/#findComment-13714088
MSI MAX 'boards, do... but I wouldn't bank on any others.
WHY NOT...?!
https://linustechtips.com/topic/1208919-is-this-going-to-work/#findComment-13714091
1 minute ago, Intelamd said:
Isn't there any mesh or air filter, i just picked the coolest looking case.
The front and the side are completely glass
Prior Build Log/PC:
https://linustechtips.com/topic/1208919-is-this-going-to-work/#findComment-13714104
4 minutes ago, Intelamd said:
Apparently, on their site they r talking about the cooling http://www.tortox.com/neon.php
They mention the inside provides cooling (somehow) but the front is literally solid glass. The original case you linked has a tempered glass side panel. The top is solid steel with no vent holes either. I mean unless I'm missing something the ONLY way for air to get in is through cracks along the side and at the rear of the case. The front fans are literally useless.
Prior Build Log/PC:
https://linustechtips.com/topic/1208919-is-this-going-to-work/#findComment-13714124
35 minutes ago, Intelamd said:
Why is that horrid power supply 250$? What the fuck?
https://linustechtips.com/topic/1208919-is-this-going-to-work/#findComment-13714158
It’s not even near a super high end power supply
Hi
hi
https://linustechtips.com/topic/1208919-is-this-going-to-work/#findComment-13714170
I‘m not an expert but it looks more like a 50$ power supply
Edit: on Amazon 3 months ago it was at a stable 80$
Edited by Drama Lama
Hi
hi
https://linustechtips.com/topic/1208919-is-this-going-to-work/#findComment-13714175
