Case airflow question, GPU fan stronger than front intake(top)
dfsgsfa
so that some heat is trapped near the cd rom area
should i turn intake fan around?
It’s unlikely but not impossible I guess.
Need more data.
there’s no information on what case, what cooler, what direction the cpu is facing, almost nothing.
 everything as case designed
coolermaster 335u, i think, rx570 nito, tower cooler  towards back, 2 intake, 1 exhaust fan
why are you concerned about that trapped heat? You can rest assured that your ODD doesn't care about it (Optical Disk Drive), especially if you don't use it
Intake through lower sidepanel slot and front, exhaust through rear fan. That's it.
My R2700XT build:  r7 2700 @4.1 Ghz max 65C - Sapphire Pulse rx 5700xt @1625Mhz 955mV 1300rpm fans, max 82C - Asrock B450 gaming k4 - Gskill Ripjaws 2x8GB @3200mhz CL16 - Be Quiet Straight Power E11 650w - Fractal Meshify C - EK-Kit S240 - NB eLoop 120mm PWM - Be Quiet Shadow Wings 140mm 1000rpm - Bitfenix Spectre LED PWM 120mm - Samsung 250GB 860 Evo - Seagate Barracuda 2TB
Peripherals:  Acer XF270HBbmiiprzx 144hz 1080p TN - CM Storm Quickfire TK - Coolermaster MK750 - CM Storm Reaper - Logitech G303 - Logitech G502 - Logitech G603
Audio:  Hyperx Cloud Stinger - Samson SR850 - Trust Screamer - Creative Gigaworks T20 II
