[Need Suggestion] Compactible UPS for PSU
Escade
Hello guys, i need an guide for choosing ups for my PC, in my country the power is really bad, its often drop and unstable,
i need a good ups with AVR to extend the lifespan of my computer (of course my PSU)
curently i got PC of this specification
PCPartPickerList
right now i consider this 2 ups to choose :
UPS CyberPower Value 2200ELCD (2200VA/1320W)
Multifunction LCD Readout
The LCD readout displays clear system information, such as power status, battery status, load status and more. It also features a user-friendly and intuitive interface, allowing users to easily manage and monitor the entire system.
Configurable Alarm
Configurable alarm immediately notifies users of unexpected issues, allowing users to resolve problems at their earliest convenience. Users can also switch the audible alarm on or off during battery mode to avoid unnecessary disturbances.
Automatic Voltage Regulation (AVR)
The UPS has built-in Automatic Voltage Regulation (AVR) function to regulate low voltages and over voltages when incoming utility power has fluctuations, thus providing consistent and reliable power to connected devices.
2200VA/1320W - AVR - (4x) Outlet Schuko
FEATURES :
Line-interactive UPS Topology
Energy Saving Technology
Simulated Sine Wave Output
Surge and Spike Protection
Phone/Fax/Modem/DSL/Network Protection
LCD Status Display
PowerPanel" Management Software
Tower Form Factor
UPS EPI e-lite e-2200 (2200VA/1320W)
INPUT
Voltage : 220/230/240 VAC
Voltage Range : 162-290VAC
Frequency Range : 60/50 Hz (Auto sensing)
OUTPUT Voltage : 220/230/240 VAC
AC Voltage Regulation (Batt Mode) : 10%
Frequency Range (Bat Mode) : 60Hz or 50Hz 1Hz
Transfer time : Typical 2-6ms
Waveform (Bat Mode) : Simulated Sinewave
Charging ability : 4-6 hours recover to 90% capacity
Full protection : Overload, discharge, and overcharge protection
INDICATIONS
LCD Display : AC/Battery Mode, Load / Battery Level, Input / Output Voltage, Overload, Faultand low Battery
Battery mode : Sounding every 10 seconds
Low battery : Sounding every second
Overload : Sounding every 0.5 seconds
Battery Replacement Alarm : Sounding every 2 seconds
Fault : Continuously sounding
Dimension, D*W*H(mm) : 370 x 135 x165
with around the same budget as those anyone know better choice ? coz i dont really know anything about ups, and there is not much review i can get to choose.
like know can this hold up my psu power with monitor too ?, when the power drops this ups will be sufficient to hold up my pc power without breaking it.
Thankss
