8700k Overclock on water
Solved by Guest,
4 minutes ago, MCManiac52 said:I've got my 8700k overclocked to 4.9Ghz at 1.28v on an Asus Prime Z370-a,
I'm using a hydro x loop, just cpu, with 1 240mm rad and 1 50mm 360mm rad.
The mac temp I saw on a cinebench r20 run was around 80 degrees.
Is the 8th gen tim really that?
For reference my buddy with a 480mm rad and a 9600k at 5Ghz 1.4 gets to about 40 degrees max
Double the temp seems too much to just be down to hyperthreading
The Tim is THAT bad yes sir.
The 9600K is soldered minus HT has a super advantage on you...... lol.
