How can I block devices from connecting to my wifi
Woxolifo
I have roommates who live with me and they refuse help pay the internet bill but still think they can use it even though we all agreed to pay a percent. I have changed the password a few times but they can still connect somehow.
Is there a way to blacklist devices or even whitelist? I do not know how they are getting the new passwords or if it just auto connects but id assume they would need to put in the new password to connect.
Is their any free programs? or is there like a router setting or something?  any advice would be very helpful. if you need any more info let me know.
Try "Netcut", it works pretty nicely for me in the past but i haven't used it in a long time
Turn on MAC address access control and only those MAC addresses that get added to the whitelist can connect.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
MAC filtering is the option you're looking for. Most routers should have this
Either white list your own devices or blacklist theirs if you know the MAC address
Depending on the router you have, you should be to do one of  the following;
  • Limit the number of device that can connect at a time
  • Set up MAC address control
  • set your passwords longer
  • turn off the WPS function
What router to do you have?
Reputation is a Lifetime to create but seconds to destroy.
 CHRISTIAN MEMBER
I think I have a Linksys brand, what is WPS? I will google too lol
Wi-Fi Protected Setup
Pretty much it is like a Bluetooth connection button, press it and connect, skips the password request entirely.
Since you have Linksys router login to your router setting and select the Wireless tab, select WPS and turn off.
What model do you have I can look up the specific UI you are using and walk you through if needed.
Edited by SansVarnic
 CHRISTIAN MEMBER
Problem is that if they have physical access to the device they can even just reset it to factory settings.
And they only way to prevent that would be to remove or block the switch. Which would also lock yourself out if you needed a reset :S
We had exact the same problem in an apartment complex (older building with the main router in the communal electricity cabinet.)
People would just reset the router whenever we changed the password. In the end we had to move the router to a locked cabinet.
Maybe the what the op needs to do. 👍
 CHRISTIAN MEMBER
bro go to ur routers ip and go to statistics page and u may find the people who are logged in and simply press block if u want more guidelines dm me and btw is the router huawei?
OP said it is a Linksys router. (5 comments previous)
 CHRISTIAN MEMBER
