External drive bottlenecked by USB port?
Solved by SupaKomputa,
What WD drive? SSD or HDD?
If HDD it won't saturate even a Gen 1, the drive can only push 2-3 gbps anyway.
So to answer your question, no the usb didn't bottleneck the drive.
Only if you put the wrong cable (usb2) then it will have usb2 speed (480mbps).
And anyway, don't game from the external drive, it's silly.
ShayOh ·
Posted in Troubleshooting1 -
Newbietobe5467 ·
Posted in Troubleshooting2 -
1
robjt ·
Posted in Troubleshooting16
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
