So have been debating for a few weeks to upgrade from a 7700k.
Options are 3700x and intel 10900k or 10700k (for better price)
I have the money for both and the motherboard.
My use is gaming, streaming, and video editing/rendering/encoding.
I just hate to try one and not know what the other is like. I can't find any quick and dirty information on the 10700k.
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
https://linustechtips.com/topic/1201276-best-cpu-for-my-use/
What about a 3900x? It just got a hefty price cut
https://linustechtips.com/topic/1201276-best-cpu-for-my-use/#findComment-13652782
This would be my choice too, or if your more gaming focused try and wait till ryzen 4th gen
PC
Ryzen 5 2600 Stock
Sapphire Nitro+ Special Edition Radeon RX580 8GB (Would Recommend)
Gigabyte B450M DS3H (Don't recommend)
Hyper 212 RGB Black Edition
Corsair Vengeance LPX 2x8GB DDR4 3000MHz CL15
Phanteks P300 (Would Recommend)
Kingston A400 240GB SSD
Seagate BarraCuda 1TB HDD
Corsair CX550M 550W  80+ Bronze
Deepcool FH-10 Fan Hub
3x BeQuiet Pure Wings 2
https://uk.pcpartpicker.com/user/marmour/saved/QTY3ZL
Peripherals
LG 24MK400H
Logitech G413 Carbon
Logitech G305 (AAA Adaptor - 10g reduction) (Would recommend)
Logitech Z150
HyperX Cloud II (Would recommend)
Moto G5 Plus (Webcam)
Phone
Pixel 3A XL (Would recommend)
*Useful Link* PSU Tier List: https://linustechtips.com/main/topic/1116640-psucultists-psu-tier-list/
https://linustechtips.com/topic/1201276-best-cpu-for-my-use/#findComment-13652785
3700x or 3900X. AMD is better for editing and streaming than intel.
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
https://linustechtips.com/topic/1201276-best-cpu-for-my-use/#findComment-13652787
The single-threaded performance on Ryzen is just slightly lower than Intel's 10th gen, although the multi-threaded performance is significantly better on Ryzen. If you find a 3800X at the same/similar cost to the 3700X, then I would go for the 3800X. You will most likely see significant performance benefit with Ryzen for streaming, rendering, and editing workloads.
Hope this information post was helpful  ?,
        @Boomwebsearch
https://linustechtips.com/topic/1201276-best-cpu-for-my-use/#findComment-13652799
Steve from Gamer's Nexus has come to the conclusion that the i7-10700K is a disappointment. The single threaded performance is basically identical to the i5-10600K for much more cost, while it doesn't offer enough multithreaded improvement compared to the i9- 10900K.
On the Ryzen side of things, it's basically impossible to be disappointed by a Ryzen 7 3700X. Boxed cooler is decent, 8 cores for basically the same experience as the i9-9900K, runs great on mid range B450 boards (though if you make content you may want to splurge on an X570 board, if you can get your hands on one)
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1201276-best-cpu-for-my-use/#findComment-13652871
Really cutting my budget with an 3900x. I have never used a ryzen, the 3700x is better price for me but it is able to overclock right?
I want to as it's fun. :D
Oh well that's basically my answer and thanks to everyone information on AMDs ryzen option. too. Ryzen XT are coming I hear to claim performance crown. I've never used an AMD CPU before now Ryzen I hear good about but my 7700k was good just time to upgrade this years games and better/faster productivity.
3700x for the price is keeping under $500 so that is what I'll be going with I think, and an Asus TUF x570 for that cause I love dark boards.
https://linustechtips.com/topic/1201276-best-cpu-for-my-use/#findComment-13652889
3700X if you have custom cooler, if not the 3800X yay? :3 (3900X for overkill)
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/1201276-best-cpu-for-my-use/#findComment-13652899
Well it is that big of a difference? A lot people say it's just a 3700x with a highier base clock for about $40 more.
https://linustechtips.com/topic/1201276-best-cpu-for-my-use/#findComment-13652904
3800X coems with better out of box cooler, Ryzen auto-OC if thermal and power is enough to do so. ;)
https://linustechtips.com/topic/1201276-best-cpu-for-my-use/#findComment-13652909
The 10700K just won most disappointing CPU on Gamers Nexus youtube video this morning....so there's that.
It it were me and Gaming was my focus here 10900K as it will also do your other tasks very well.  But if you want better all round performance and are cool with what might be unperceivable fps gaming differences or you game in games that are already maxed out....then a 3900x is the way to go, step up from the 3700/3800x and you'll be much happier with the higher clock speeds and extra cores.
Consultant by day, terrible youtuber by night.  https://www.youtube.com/channel/UCDDr_uxt6MSeUTsd8hmDOXw
https://linustechtips.com/topic/1201276-best-cpu-for-my-use/#findComment-13652910
Well if I won a 10700K I wouldnt exacly say no thanks... :P
https://linustechtips.com/topic/1201276-best-cpu-for-my-use/#findComment-13652927
It is not the same as the 3700X with higher base clock, although you could say that it is a better binned version of it, 3800X is better for overclocking if you want to push the performance even further than the automatic boost OC and there is a better cooler included.
        @Boomwebsearch
https://linustechtips.com/topic/1201276-best-cpu-for-my-use/#findComment-13652962
The rumors aren't very consistent, some say 3800 XT and some say 3850X. I'm still not convinced these processors exist
Primary PC:
PSU tier list
https://linustechtips.com/topic/1201276-best-cpu-for-my-use/#findComment-13652994
Might get 3900x just from $291 to $421 after tax at micro center here is the cheapest I could find. I do like seeing the "12/24 threads" though, ahah
Also I'm on a AIO. 3800x does have a better price so that I think would be the highest I'll go. Thanks you all.
You right. Makes more sense to just say zen3 4000.
https://linustechtips.com/topic/1201276-best-cpu-for-my-use/#findComment-13653012
