Help finding the connector I need
Solved by kirashi,
4 minutes ago, MartinWake said:
Gotcha, great video! You'll want the cables with 2x 6+2pin VGA connectors on one end and 8 pins in a solid block on the other end end if the new graphics card requires 2x 8pin connectors total. The end of the cables with the 6+2 pin split should go into your GPU, and the other end that's a solid block of 8 pins total should go into your PSU. The CPU 4+4 pin cable is used for motherboards with a CPU power connector that require all 8 pins to be plugged in.
