First new PC build (comments appreciated & help appreciated)
Solved by F.E.A.R.,
9 minutes ago, frenzen said:Hello I tried to mount the stock wraith cooler onto my motherboard but the holes did not fit after taking off the plastic mount things, felt like I would need to take bend the motherboard a bit. What should I do?
Maybe you're doing something wrong. Check this video to see if you got things right.
