Do i Need an anti static wrist strap to clean out a pc?
Solved by JJCooper_,
6 minutes ago, Mitzy said:Do i need an anti static wrist strap to clean out a pc
If you are just cleaning out dust, then there is no need for one. But if you are taking out components like the Mobo, then you might as well wear the wrist strap so you dont short something or build up static.
Featured Topics
deanx ·
Posted in Troubleshooting2 -
Bkstrat ·
Posted in Troubleshooting0 -
3
remo233 ·
Posted in Power Supplies4 -
2
3
VioletGiraffe ·
PietervdWiel ·
Posted in New Builds and Planning8 -
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
