Are you sure your waterblock is compatible with your specific card? Before you start ghetto blasting shit off.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
Specific model and block would be appreciated
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
10 minutes ago, arcadeperfect said:
Hi,
The fan header in the photos is preventing the waterblock from making contact.
Can anyone recommend the safest way to remove it?
Thanks!
We really need to know what card and what block your using. Are you sure its compatible....?
If EVERYTHING else is correct, none of the capacitors are in a place that won't support, the VRM and RAM is all identically spaced out and correctly located etc, I wouldn't modify the card, I would dremel that plastic part of the water block a bit, assuming that section doesn't have any water in it which it shouldn't. since there isn't any coldplate in that area.
Card is Gigabyte RTX 2080 ti  turbo and block is EK vector. Worth noting that the card is reference PCB except with normal fan headers as opposed to the proprietary ribbon cable the founder's eddition came with.
However I have to confess that I've rechecked the EK website and the card isn't listed in the compatibility table. That's confusing because I definitely checked. Maybe I was drunk.
I got it off Amazon so I could return it and get something else.
Sadly it isn't plastic that it's hitting, it's the actual metal of the waterblock.
Oh, I saw that wrong.... That section of the metal very well may not have any water flow above it tho.... If that is the case, can just dremel that metal down. But if it does, looks like that won't work. You can desolder the fan header..... but, i mean, I am not I would do that, and I have milled pockets and stuff in water blocks to make them fit my cards in the past that were slightly non-reference.
Now that I've discovered my card isn't even officially compatibly (was sure it was) and Amazon accepts returns, I think I'ma play it safe and get a different block.
