Need a case
Go to solution Solved by TVwazhere,
3 minutes ago, fpo said:
TL;DR
3 HDD, 1 SSD, ATX motherboard, full size GPU. Need case. Dusty room, need USB ports on front. AMD GPU & CPU non-modular PSU, at least three 3.5 inch HDD (room for more would be nice)Room for a DVD drive is nice, I am always out of USB ports, something nice looking, but no RBG, Silver colour is nice, as it would match my HP monitor (27es) but I'm not too picky, Budget of up to maybe $150 but $80~120 target.
Gunmetal Define R6 $150
https://www.newegg.com/gunmetal-fractal-design-define-r6-atx-mid-tower/p/N82E16811352093?Description=define r6&cm_re=define_r6-_-11-352-093-_-Product
An alternate would be the NR600 with ODD, but currently the ODD version is out of stock on both newegg and amazon.
TL;DR
Long:
I have an aluminum "Original Antec Lanboy" as seen in Linus' "my first gaming PC" video. The case is a bit dated though its lightweight is nice. Also the door broke off so it looks less nice.
I have a cat & my room has a carpet so my computer can get a little dusty.
My PC has an AMD GPU & CPU so it gets a bit toast in there. (Especially with how small the case is.)
I do lots of game development work & play some unreal engine games so I need good airflow to make sure my components don't overheat. I'm tired of being ghetto & leaving the side panel off.
I need a case that can fit a non-modular PSU, (so a basement could be a nice quality of life feature) at least three 3.5 inch HDD (room for more would be nice)
At least some room for an SSD 2.5 inch. Room for a DVD drive is nice, but not super necessary. Sometimes I put dvd movies or music cds in to listen to. Not a deal-breaker.
One of my main problems with this PC is that I am always out of USB ports. My motherboard has room on it for more but, my case is super dated.
I would like something nice looking, but no RBG. I've seen some PCs with white lights or blue lights, but I don't really want to pay extra for it. Silver colour is nice, as it would match my HP monitor (27es) but I'm not too picky. I don't have any fans, but if I need to buy some, I'm open to it. Don't budget for fans in the case budget. If a case comes with quiet fans, that's okay. If you don't know if they're quiet, don't stress about it. Something nice to work in would be a nice change. Nothing too "gamer." A "modern" aesthetic is kinda what I'm thinking. Sidepanel window is neither here nor there. If it has a hidden back cable management spot, no sidepanel. If my cable management looks bad, then I don't want to see it. I might need dust filters. I'm all air cooling right now. I don't think I will be upgrading to get a watercooling package. The AMD cooler that comes with Ryzen CPU seems to work fine. I don't overclock.
My budget would naturally lean towards lower cost, but I won't cheap out. I'd be okay spending extra as I can keep this case forever if need be. I'm located in the US mainland & would like to order from Newegg. Budget of up to maybe $150 but $80~120 target.
https://linustechtips.com/topic/1189621-need-a-case/
TL;DR
https://linustechtips.com/topic/1189621-need-a-case/#findComment-13565531
This is why I love you :)
Seconding the Define R6.  Watch this, impossible not to want it...
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1189621-need-a-case/#findComment-13565545
4 minutes ago, TVwazhere said:
I like this one. It has all those dust filters? oh, the video jstudrawa posted answered that question.
That's the case I was kinda picturing in my head. Thanks!
It even has a hidden slot for a DVD drive.
u da man.
This one looks nice but has only like 2 front USB ports.
I agree. It shows off all the features one would really want.
4 minutes ago, Enzo1001 said:
i would go with a sharkoon ai 7000 cuz its cheap, side windows and spacce for radiator
That's a very nice looking case, but I think I like the one TVwazhere posted just a little more.
Thank you for the suggestion!
https://linustechtips.com/topic/1189621-need-a-case/#findComment-13565565
And I love you random citizen. - GIF on Imgur
https://linustechtips.com/topic/1189621-need-a-case/#findComment-13565598
