Depends what you want to spend. Arctic eSports DUO is a decent option
Just now, OreoShake said:
Does anyone know a good Aftermarket Cooler for my R5 3600x ?
 whether its a liquid one or an air one.
I heard about Notcua but im not sure which one though so please list me a couple to look for!
Thanks!
The best air coolers are the Noctua NH-D15 and Dark Rock Pro 4.
The Scythe Mugen 5 or Arctic Freezer 34 are pretty good more budget options too.
With these sorts of larger air coolers, you should definitely check if they will fit inside of your case.
im most likley going to get a NZXT case or a Mid ATX case
