Display Port V2.0
Go to solution Solved by Eigenvektor,
3 minutes ago, Brukuman said:
So how am I able to tell if my GPU supports certain Display port cables.
As @Enderman said, cable is the same. What's you GPU model? You should be able to find the info online which DisplayPort version your GPU supports.
11 minutes ago, Brukuman said:
Hello, I got myself a 240 hz monitor, will the display port 2.0 run 240 hz on 1080p and support G-sync/Freesync?
There are no GPUs with DisplayPort 2.0 yet. So you should most likely check what DP version it supports.
DisplayPort 2.0 has a maximum bandwidth of 80 Gbps (77.37 Gbps data rate). 1920x1080 @ 240 Hz requires 14.93 Gpbs, so yes absolutely doable. Whether Gsync/FreeSync is supported depends on your monitor. Check its manual whether that is supported and at which frequencies (not necessarily up to the monitor's max refresh rate)
https://linustechtips.com/topic/1187125-display-port-v20/#findComment-13548235
All displayport cables are the same.
They are just cables.
https://linustechtips.com/topic/1187125-display-port-v20/#findComment-13548267
https://linustechtips.com/topic/1187125-display-port-v20/#findComment-13548277
