So I'm finally building my first Gaming/streaming/editing rig. I already own the m.2 (plan on getting larger one later),Graphics card, and case. I'm concerned with comparability issues will the ram fit under my cooler? Also par picker says "he MSI B450 GAMING PRO CARBON AC ATX AM4 Motherboard has an additional 4-pin ATX power connector but the Cooler Master MWE Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply does not. This connector is used to supply additional 12V current to the motherboard. While the system will likely still run without it, higher current demands such as extreme overclocking or large video card current draws may require it."
AMD Ryzen 5 3600X 3.8 GHz 6-Core Processor
                  $199.99
CPU Cooler     Cooler Master Hyper 212 RGB Black Edition 57.3 CFM CPU Cooler $44.99         $44.99
Motherboard     MSI B450 GAMING PRO CARBON AC ATX AM4 Motherboard $159.99   FREE     $159.99
Memory     G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3600 Memory $99.99   FREE     $99.99
    Add Additional Memory
Storage     Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive $50.99   $3.99     $54.98
Storage     Western Digital Blue SN550 500 GB M.2-2280 NVME Solid State Drive $69.99   FREE     $69.99
    Add Additional Storage
Video Card     MSI GeForce RTX 2070 8 GB Video Card           $419.99
Case     Lian Li LANCOOL II-X ATX Mid Tower Case $149.99         $149.99
Power Supply     Cooler Master MWE Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply $99.99         $99.99
Operating System     Microsoft Windows 10 Home OEM 64-bit
https://linustechtips.com/topic/1186236-first-build/
id drop down to the regular 3600, with the $25 saved spend on a better cooler like a noctua ND-D14/15, get some 3600 CAS 16 instead of 18, get a 2070 super or a 5700 xt, and review your PSU choice vs. the tier list in the cases and power supplies forum.
EDIT: or skip the cooler completely to use the included one, or spend $20 on a basic one like you listed, and redirect the money to gpu/etc.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1186236-first-build/#findComment-13541679
welcome to the forum! Nice :)
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
https://linustechtips.com/topic/1186236-first-build/#findComment-13541697
-Moved to New Builds and Planning-
https://linustechtips.com/topic/1186236-first-build/#findComment-13541819
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1186236-first-build/#findComment-13543341
