Cooler Master H500P Mesh 200mm Fan Lights
Solved by TVwazhere,
15 hours ago, Taintedmind said:I've recently purchased the Cooler Master H500P Mesh and I knw it's blasphemy, but is there a way to a turn off the front lights on the case on the 2x 200mm fans? I'm waitin for the new computer hardware to come out this year, then I'm goin to build in it and use my current PC as a hand-me-down to my g/f, but I'm wonderin if there's a way to disable the lights, since idc for LEDs/RGB; any useful info is appreciated!
Yes. Simply dont plug in the RGB cable to anything, as it is separate from the normal 3 pin fan connector.
