Need help, Sapphire R7 260x OC ed. 2gb Flickering lines on idle or web browsing
Download your drivers directly from AMD.
Beta Drivers are not 100% guaranteed to work with everyone (that's why there is a note saying "AS IS.")
"Note! This driver is provided "AS IS" and under the terms and conditions of the End User License Agreement provided there within."
- AMD.com
And yes, 14.2 Beta is now up on AMD's website.
The stable, WHQL certified, driver is still 13.12.
When uninstalling drivers, use Display Driver Uninstaller, in safe mode. it will completely clean your os from the drivers. I had the same issue with my R9 290, also try to use stable drivers, i believe the 13.2 are the latest ones.
Yes i i did both of what you both said, and didn't work so i guese -rascal is right, the 14.1 beta might not have been compatible for some reason with my r7 card.
But i would like to Thanks you guys for all the help, really appreciate it a lot. got the 14.2 installed, no problems anymore, no flickering lines, and no problems during installation.
Now if its not too much to ask...
Can you help me with this new problem
http://linustechtips.com/main/topic/121375-help-with-ati-radeon-mobility-hd-4570/
