A small but useful tool
so there's this nifty utility I've been using for a couple years called "file menu tools" and I'm talking with a dev about this idea how they should totally add this feature and he chimes back "that sounds a lot like this thing we already did" called "unpack folder" turns out I've had the ability for ages and for some reason either forgot about it or didn't notice it before, it's exactly what I wanted, the whole thing all said features auto delete empty folder, right click, auto rename, etc
so if you'll excuse my derp
thanks for trying anyway
can't tell you how much I've been looking for this exact feature for the last few weeks seemingly without finding it already online in the particular form I was thinking of
since anything else I came across basically you had to launch it as a stand alone program without using selected folders, you had to navigate because apparently drag and drop was just too much work, etc
I just feel so much better now
