gpu PCIe cables help
Solved by bob345,
You most definitely will not want to use adapters to connect to the 4 pin molex. Those connectors are not rated for that kind of current. If it doesn't immediately kill the psu it will most certainly melt the connector/wire and possibly start a fire.
4
thedood2k ·
Posted in Power Supplies2 -
DARTHDIVIDER0213 ·
Posted in Troubleshooting8 -
1
Xx-albinos-xX ·
Posted in Troubleshooting10 -
2
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
