Hi there!
I am looking for a case upgrade. Currently I have a Corsair 270R but I am looking for something more modern (Tempered glass) and maybe with better airflow. I currently have 2 2.5inch drives and one 3.5inch. The motherboard is an E-ATX board. so a lil bigger than usual (Asus Rampage VI Apex 2066)
This is how It's looking currently (sorry for the horrible quality lol):
This current case is closed on the front which is not ideal for my 2x140mm radiator in push & Pull. I would love to mount in the top of the case. Which was sadly not possible. Let me know what you guys think!
https://linustechtips.com/topic/1177717-case-upgrade-help/
any one of those huge li lan li cases would be perfect
http://www.lian-li.com/pc-o11-dynamic/
NOTE: I AM NEVER ALWAYS RIGHT, BUT I AM HAPPY TO HELP ANYWAY I CAN
Tag me @WambleCropped or quote me so I can see your reply
My Rig: RTX 2060, R7 1700X, Samsung 860 500GB, Masterlite Liquid Cooler, Asrock Pro B540,16GB of RAM G.Skill 2133
PSU Tier List                    SSD Tier List                              Graphics Tier List
https://linustechtips.com/topic/1177717-case-upgrade-help/#findComment-13479366
Damn, that does look good! For some reason they aren't available in the stores I get my stuff.I may just get it shipped from the US lol.
https://linustechtips.com/topic/1177717-case-upgrade-help/#findComment-13479374
The PC-011D isnt actually that much bigger than the Corsair 275
https://linustechtips.com/topic/1177717-case-upgrade-help/#findComment-13480401
I have been looking at it for a while now. I am thinking about going for the XL tho. Because I am planning on custom watercooling my system soon when I also have my RTX cards
https://linustechtips.com/topic/1177717-case-upgrade-help/#findComment-13481383
How many radiators/sizes are you planning on using?
https://linustechtips.com/topic/1177717-case-upgrade-help/#findComment-13481871
21 hours ago, XHD600X said:
Hi there!
I just decided to order the fractal meshify s2 good airflow and think it said it holds up to a 420mm radiator in top. Worth a look down sizing from coolermaster haf x case.
https://linustechtips.com/topic/1177717-case-upgrade-help/#findComment-13482972
I remember when the Haf X was the shit to have lol. I'll take a look!
https://linustechtips.com/topic/1177717-case-upgrade-help/#findComment-13482977
2 hours ago, XHD600X said:
atleast 2. 360mm in the top, and a 280mm in the bottom. With an EK distribution block.
Unless you're doing dual GPU's, the Original version can easily handle all of that unless you just really want the space for some reason.
https://linustechtips.com/topic/1177717-case-upgrade-help/#findComment-13483274
That is the plan, going big this time. Getting the i9 10980Xe (Already had the 2066 board otherwise I would've gone Threadripper) and dual RTX 2080.
https://linustechtips.com/topic/1177717-case-upgrade-help/#findComment-13483759
