Help me understand Ryzen temps please.
Hi all,
Just recently bought and installed a new Ryzen 7 2700X into my PC the specs of which are as follows;
ASRock Steel Legend B450
Ryzen 7 2700X /w Stock Cooler
Sapphire Nitro Rx590 8gb
Corsair Vengence LPX 16gb on XMP @ 3200
Fractual Design Focus G Case
2 x 120MM Intake fans on front
1 x 120MM Exhaust fan at back
So I'm quite new to all this and since this is the first good CPU I've bought I decided to try it on CINEBENCH R20 so see how it all went.
I did it with Ryzen Master running to look at my CPU temps and saw that it peaked at 79 degrees celsius at the end of the test and I've been sat here looking at the idle temps which are jumping between 34 degrees and 42 degrees 30minutes after the test.
Are these normal temps? I havent really paid attention to temps as I only had a Athlon 200G before so it wasnt ever an issue. But now I am worried I put the stock cooler on wrong maybe even though I was careful and clipped both retention clips in fine and felt the unit and it was tight and secure.
Are those temps normal?
Edited by LogicalDrm
Fixed text
https://linustechtips.com/topic/1176579-help-me-understand-ryzen-temps-please/
3 minutes ago, dom_kai said:
Hi all,
that seems fine. as long as it doesnt go above 85 to 90c for extended periods, it'll be ok
Either @piratemonkey or quote me when responding to me
1 minute ago, Applefreak said:
Yes, those are normal temps for the stock AMD cooler. If you are concerned a decent 30 to 50 usd cooler will get those temps down in into the low 70s.
Well I did intend on swapping it out for a Dark Rock Pro 4 in a few months. Seems like such a waste but the Wraith Prism looks good lol
18 hours ago, dom_kai said:
Well thats a relief lol
I was worried because the CPU cooler keeps revving up and down even when I just have Chrome open and nothing more. I'll keep the temp monitor running while I do a bit of gaming and see what it looks like.
That means fan curve is too aggressive. You may need to tweak it.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
