Most power efficient Ryzen 3000 capable motherboard.
23 minutes ago, Totsuzen said:First of all, I have this account since 2016 and I am now making my first post, so hi everyone!聽
聽
I am planning on building聽a 3rd gen Ryzen system that is聽going to聽be powered on聽24/7. Essentially聽a multi-purpose home server performing聽non-critical tasks.
I'm aware that none of the AM4 motherboards聽will idle as聽efficiently as the intel offerings from the same manufacturer and price range. Having said that, what budget AM4 motherboard (~80 USD) do you guys recommend having power efficiency in mind (especially idle/base clock wattage)?
聽
I was looking at the cheapest B450 offering from ASUS (Prime B450)聽and it looks pretty solid. I want to pair it with a Ryzen 3 3200G and 16GB of RAM (2x8). Looking for total DC power draw measures on all rails if possible so the power supply efficiency is not a variable to account for.
Are any reviewers聽measuring those values? (you would have to measure the amperage between the power supply and motherboard).聽I've been looking聽for any tech blogger / reviewer聽that compares different motherboard models and makers while using he same CPU but found nothing relevant聽(maybe I just suck at googling).
聽
I'm aiming for ~22W idle from the wall@ 230V AC, I'll be using an older corsair聽80+ "White" PSU which has聽a 75% efficiency on low loads according to its efficiency curve聽so that would be around 16.5W total DC wattage on idle from all rails.
(Just for the system itself, no peripherals, no storage except for solid state OS drive.)
I'll be running a headless linux-based聽distro聽on it. That means no desktop environment, just the CLI.
聽
Suggestions/Opinions聽are welcome. Thanks in advance 聽
The B450 chipset is 5w.聽
1 stick 8GB DDR4 module at 1.2v 2133mhhz is about 3w. x2 6w
The 3200G will be about 25-30w idle. 50w'ish at load.
聽
Not counting other peripherals.聽
聽
You'll be close to your goal I think.
聽
