How to fix home WiFi router
alwinaind
I have a D-Link DIR-816 dual channel router at home. Recently my mom accidentally pulled its plug out. After that when I switched it back on, it was receiving signal from the WAN port but it was not sending 2.4 GHz or 5 GHz WiFi signals. The LED's for both the channels were OFF, only the power and WAN port LED's were ON. I couldn't even get any connection via an Ethernet cable. Any possible fixes?
Edit: I forgot to mention I tried the basic troubleshooting of rebooting, and reseting the router didn't work.
Edited by alwinaind
use the hard reset button
If you're interested in a product please download and read the manual first.
Don't forget to tag or quote in your reply if you want me to know you've answered or have another question.
Tried that as well, didn't work
Did you keep it presse for at least 5 seconds, because just pressing it is for WPS.
(Source: https://setuprouter.com/router/dlink/dir-816/manual-2389.pdf)
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
