Nuxt JS rendering mode, SAP vs universal
Solved by MoVo,
I don't know about Netlify+ Nuxt specifically, but Server Side Rendering usually improves your SEO by quite a bit. A Single Page Application is rendered entirely by the JavaScript execution, which Webcrawlers don't always do. Serving static HTML fixes this constraint and makes it much easier for the webcrawlers to index your site. So since you want to build a blog, I'd recommend you go with Server Side Rendering.
