is pc building simulator accurate for physical compatibilities?
i need to know if my cpu cooler will fit in my build and pc part picker said that some physical dimension restrictions cannot be automatically checked.
so has anyone tried using pc building simulator to measure dimensions?
https://linustechtips.com/topic/1172864-pc-building-simulator-accurate/
Hey there. PC Building Simulator is... not the best when it comes to physical compatibility. Um... I've had instances of radiators being installed through case fans and HDD cages... Also I've successfully installed SSDs through the graphics card...
Anyway! Would you mind listing what CPU cooler and case or the system specs you're interested in? We'll probably be able to help you out. 😁
正直に生きる、一度きりの人生だから
Keeb Weeb LinksCustom Mechanical Keyboards | #KeebWeebClub
'Chew Builds: Hoshī (PC) | Okashī (PC) | K-4398 (Keeb) | Eighty #391 (Keeb) | R2-968 (Keeb) | MGK64 (Keeb)
ryzen 5 2600x
phanteks p300
evga geforce rtx 2060 ko ultra gaming
cooler master hyper 212 evo
3 rosewill 140mm 89.55 cfm fans
23 minutes ago, MKSanic said:
ryzen 5 2600x
phanteks p300
Cool. The Cooler Master Hyper 212 EVO has a height of 160mm, the Phanteks Eclipse P300 has a CPU cooler clearance of 160mm. Two things to note: one, the fit will be pretty snug, I image you'll have maybe 1mm - 2mm of space between the CPU cooler and the side panel, and two, the Cooler Master Hyper 212 EVO doesn't seem to play nicely with high profile RAM (unless you're willing to adjust the CPU cooler fans slightly, like in this video).
Graphics card clearance also checks out, the Phanteks Eclipse P300 has a graphics card clearance of 330mm, which is more than enough room to accommodate your 202.1mm graphics card. I find it a little odd you're going with Rosewill's 140mm fans, are they good?
Heh. Cool.
正直に生きる、一度きりの人生だから
you should never trust a computer fan's datasheet. they are know for having big variables, even the crucial number, the fan speed, 10% tolerance on premium skus are considered normal. so what about things that dont say in the numbers? balance, viberation, cable length, etc?
and should i remends you that there is no industry standard on how to evaluate fan performance? those cfm numbers? i dont know how to reproduce them. so when it comes to these parts, price is the only thing that matters, apart from those rgb nonsense.
how i value a fan is 3 things: blade to frame gap (tells you how good the tooling is); current (tells you what kind of speed it operates, notice it does not determind the rpm) and blade shape( shallower angle with wide blades means high pressure low volume, vice versa)
why everybody post the spec of their rig here? i dont! cuz its made of mashed potatoes!
It fits the case just fine. There are plenty of examples online: https://pcpartpicker.com/builds/by_part/hmtCmG#e=1569,1757
As for the ram, you haven't mentioned it.
Please use pcpartpicker permalinks for easier sharing.
f85ac460ec40f5998b6dbed94de1bee2.gif&key
12 hours ago, MKSanic said:
89.55 cfm pwm for $14 also revies say they are quiet
Please use model names. They're Hyperborea, rebrands of Akasa's Apache / Viper and are pretty good.
Moved to Air Cooling.
Just now, MKSanic said:
i like the look very much.i dont mind the restrictive airflow
Sure. I was thinking if you are limited by budget or availability. P300A and P350X are both better in terms of cooling performance.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
10 hours ago, juandeag2k said:
I wouldn't trust it entirely.
I wouldn't trust it at all. If anything, it's just calculating numbers from known SKU part numbers and their public benchmark numbers. Basically, a game engine that's calculating spreadsheet numbers with 3D graphics overlaying polygons. That's it. I seriously doubt there's any air fluid-dynamic physics simulations going on in regards to airflow.
