Overclocking I9-9900k and temps
Solved by Jurrunio,
9 minutes ago, Dirael said:I don't remember where I read those reviews.
One last question, If I were to buy Corsair ML140 and replace stock fans, would it really make a difference, or improvements would be minimal (3-4C)?
ML140 non RGB should help a decent margin (expect at least 5C drop), RGB variant wont help as they are limited to 1200RPM.
But with non RGB radiator fans, I'd rather use other models like the Noctua NF-A14 or Arctic P14. Corsiar use MLs on high end AIOs not because they are that good on heatsinks or radiators, but they dont have anything better. The SP are rather loud, AF lack pressure, HD and LL dont perform well in general, focusing on lighting above all else.
