S1220A paired with DT 770 Pro 80 ohm
Solved by rice guru,
Yeah you should be fine I would try the 250 ohm first sounds noticeably better than the 80 o and if that doesn't work out then return it and grab the 80 ohm Instead
Featured Topics
kuzzikan ·
Posted in Troubleshooting0 -
genshin ·
Posted in General Discussion3 -
Oufkiz ·
Posted in Troubleshooting1 -
Oufkiz ·
Posted in Programs, Apps and Websites2 -
17
ItsHunterM8 ·
Posted in Troubleshooting15 -
2
5
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
