Too many connectors for my PSU? aorus Rtx 2070 super + aorus x570 motherboard + corsair mr650x
Solved by minibois,
5 minutes ago, elzix123 said:Sorry, Im running x570 Master
The motherboard doesn't mention either EPS connector as default, so you should be fine using either.
11 minutes ago, elzix123 said:Just to clarify I know that for cpu motherboard I should use proper cable (left one) and for gpu the PCIe one (the one on the right).
Yes.
11 minutes ago, elzix123 said:Still if I connect only 1x 8pin cpu to my mobo will this be enough? Im running a ryzen 3900x cpu
3900x uses up to 150W, so one connector is totally fine.
