Shoul i go for 2k or 1080p 144hz with 1080ti?
yasincengiz
I currently have a 1080p 60hz display and wanted to change it since i just upgraded my gpu with these specs which one do you think is best for me 2k 60 or 75Hz or 1080p 144hz?
GPU: 1080Ti
CPU: i5 6600K 3.5GHz base clock
RAM: 2x8 16GB 2133mhz
2k is 1920x1080 2.5k is something like mine. That is me nitpicking though. lol.
2K is absolutely fine with your build. I'm running 2560x1440p (2.5K) 144hz and getting well over 100fps in most games. I running a 1070 ti with a OC on it.
RE3 DEMO With basically everything max running 4GB on texture but everything else besides shadows (high) at max. Runs about 120-90 at lowest. No hitches.
Long and short of it I would do the upgrade unless your doing esport games only.
First watercooled System
Build Name: Frost
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: EK Mystic Fog
PSU: EVGA Supernova 1000w G3 w/ custom modmesh black & white cables from cablemod
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: HyperX Quadcast
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS
Camera: Razer Kiyo Pro
17 minutes ago, Alienware 15 R2 said:
1080P 144hz.
Thats the best for your GPU to handle.
Are you saying this because i have not-so-powerful CPU? That's one of the reasons why i asked it because lots of people play 2k with 1080ti trouble free
