Empty same cell from many excel spreadsheets
Go to solution Solved by Franck,
You could write a small 10 lines in C# to do this, as long as you have microsoft office installed.
i'm not 100% sure of the syntax as i don't use the core office library to edit excel files but it must be something along these lines
foreach (var file in Directory.GetFiles("C:\\folder1\\folder2\\"))
    // create excel app
    var excelApp = new Microsoft.Office.Interop.Excel.Application();
    // open the file
    var workbook = excelApp.Workbooks.Open(file);
    // load a specific worksheet
    var worksheet = workbook.Sheets[1] as Microsoft.Office.Interop.Excel._Worksheet;
    // get the cells range
    var range = worksheet.UsedRange;
    // empty cell value row 3, column 6
    range.Cells[3, 6].Value2 = "";
    // close workbook and app
    workbook.Close();
    excelApp.Quit();
Hey all,
first of all, I'm not sure whether this is the right place to ask, so I'm sorry if it isn't.
I couldn't find the answer by googling, so here goes:
I have a folder of excel spreadsheets from which I need to empty the same cell for all of them (say, D17). It was only needed for a sum, but needs to be empty for further processing in a different program.
It's a real PITA to open each one up and remove the cell, so I thought there must be a way to automate this. Is there?
Best wishes,
John
You could loop through the directory and open every excel file and clear that specific cell?
I'm pretty sure if you spent some time searching, you'd find something.
Aftter 1 search:
https://www.e-iceblue.com/Tutorials/Spire.XLS/Spire.XLS-Program-Guide/Cells/How-to-remove-the-value-and-format-from-Excel-Cell-range.html
https://www.codeproject.com/Questions/785053/Remove-the-content-in-cell-using-csharp
Two very useful posts after  a single search. When trying to google how to do a specific task, like what your trying to do, break it down into smaller ones and search how to do that. For instance, how to loop through a directory and find all files with the .xls file extension, then I'd search how to remove a specific cell value in excel in X programming language.
    // create excel app
    // open the file
    workbook.Close();
    excelApp.Quit();
    // create excel app
    // open the file
    workbook.Close();
    excelApp.Quit();
Thanks, I'll try that!
