Why a 3600X over a 3600 + some overclocking? You have pretty much the same headroom on both with PBO
Why that specific cooler? You can get a 360mm cooler for less in white that performs better
Look at X570 unless you know that X470 board comes with an updated BIOS and there is a nice x570 board for $4 more.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
I'd knock down the PSU, you don't need 750w. Then use the money saved to get a 1TB SSD.
Other than that it looks fine. I personally don't like AIOs so I'd go with an air cooler, but 🤷‍♂️
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($174.99 @ Amazon)
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler  ($84.46 @ Amazon)
Motherboard: Asus TUF GAMING X570-PLUS ATX AM4 Motherboard  ($164.99 @ Newegg)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory  ($82.99 @ Newegg)
Storage: Sabrent Rocket 1 TB M.2-2280 NVME Solid State Drive  ($149.99 @ Amazon)
Storage: Seagate BarraCuda 4 TB 3.5" 5400RPM Internal Hard Drive  ($86.37 @ Walmart)
Video Card: Gigabyte GeForce RTX 2070 SUPER 8 GB WINDFORCE OC 3X Video Card  ($489.99 @ Newegg)
Case: Corsair iCUE 465X RGB ATX Mid Tower Case  ($129.99 @ Amazon)
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($124.99 @ Corsair)
Total: $1488.76
Generated by PCPartPicker 2020-03-22 14:39 EDT-0400
3600x is an overpriced slightly OCed 3600 with a slightly better cooler but for quite abit more money. 3600 would be a better option.
The be quiet! Dark Rock Pro 4 costs alot less than the Corsair h100i Platinum, and performs pretty much the same, even better in certain scenarios.
This X570 board is less than 20 bucks more and a much better board overall.
1tb ssd instead of 500gb, you can never have too much storage.
Main Rig: CPU: AMD Ryzen™ 9 3950X Processor (Stock, -0.1V offset)  /// Motherboard: Asus Pro WS X570-Ace /// CPU Cooler: Deepcool GamerStorm Castle 360 RGB V2 /// GPU: Gigabyte AORUS GeForce® RTX 2080 SUPER™ 8G /// RAM: G.SKILL Ripjaws V 128GB (4x32GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R6 USB-C Blackout TG /// PSU: Corsair RM850i /// Storage: 500GB Samsung 970 EVO Plus NVMe (boot) + 1TB WD Black SN750 NVMe (Working Drive) + 2x 1TB Samsung 850 EVO 2.5" SATA SSD RAID0 (Game Library) + 2TB Seagate BarraCuda (Backup) /// OS: Windows 10 Pro
Peripherals (Main Rig): Mouse: Logitech MX Master 3 + Logitech G903 Lightspeed /// Keyboard: Keychron Q1 ANSI - JWK Lavender Linear Switches (TX Switch Film, Krytox 205g0), Durock V2 Stabilisers, Polycarbonate Plate, Tape Mod, GMK Blue Samurai + Keychron K4 V2 Hotswap RGB Aluminum Frame - Gateron Milky Black (Deskeys Switch Film, Krytox 205g0), Foam Mod, Tape Mod, GMK Rainy Day PBT Clones /// Tablet: Wacom Intuos M BT /// Monitor: 4x LG 27UL500-W (4K IPS Freesync) /// DAC: Focusrite Scarlett 2i2 /// Speakers: Logitech Z625 /// Mic: Focusrite CM25 MkII /// Headphones: Audio-Technica ATH-M50x, ATH-LS70iS IEMs /// Racing Wheel: Logitech G920 Driving Force with Shifter /// Eye Tracker: Steelseries Sentry  /// External Drives: 500GB Samsung T5 SSD (Working Drive)
Home Server - NASty: CPU: AMD Ryzen™ 7 2700x Processor /// Motherboard: Asus PRIME X470-Pro  /// CPU Cooler: be quiet! Dark Rock Pro 4 /// GPU: Gigabyte GeForce® GT 1030 OC 2G /// RAM: G.SKILL TridentZ RGB 64GB (4x16GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R5 Window /// PSU: Corsair RM750x /// Storage: LSI SAS 9211-8i (IT Mode) + 10x 4TB Seagate Exos Enterprise Drive /// OS: UNRaid
Tester Rig: CPU: AMD Athlon™ 200GE Processor /// Motherboard: Asus ROG Crosshair VI Hero WIFI  /// CPU Cooler: AMD Wraith Prism RGB /// GPU: Palit GeForce® GTX 1050 2GB StromX /// RAM: Klevv Bolt 8GB (1x8GB) 3000Mhz CL15 /// Chassis: The AMAZING $30 "Computer Case"! /// PSU: Seasonic Focus GX-750 /// Storage: 1TB Samsung 860 EVO 2.5" SATA SSD + 240GB Transcend SSD220S 2.5" SATA SSD /// OS: Windows 10 Pro
Laptop (Asus UX430UN): CPU: Intel® Core™ i7-8550U Processor  /// GPU: NVIDIA GeForce MX150 /// RAM: 16GB 2133Mhz /// Storage: 512GB SanDisk SD8SN8U512G1002 (boot) /// OS: Windows 10 Home
Other Tech: Console: Xbox One S 1TB, Apple TV 4K /// Printer: Canon imageCLASS MF635Cx /// Phone: Apple iPhone 12 Pro Max 256GB Graphite (Daily Driver)  /// Tablet: Apple iPad 9.7-inch Wi-Fi (2018) 32GB + Apple Pencil (1st Generation) /// Headphones: Apple Airpods Pro, Sony WF-1000XM3, Sony WH-1000XM3 /// Smartwatch: Apple Watch Series 6 GPS Space Grey
Cameras: Bodies: Canon EOS-1D X Mark II, Canon EOS 5D Mark IV,  Sony A6000 /// Lenses: Canon EF 24-70mm F/2.8L USM, Canon EF 16-35mm F/2.8L II USM, Canon EF 70-200mm F/2.8L IS II USM, Tamron SP 150-600mm F/5-6.3 Di VC USD G2 (Canon), Sony SEL-P1650 E 16-50mm F3.5-5.6 PZ OSS /// Lighting: 2x Godox SL60-W Continuous LED, 2x Canon Speedlite 580EXII /// Tripods: Leofoto LS-324C Carbon Fiber Tripod + Leofoto LH-40 Ballhead, Leofoto MC-80 Multipurpose Clamp, Triopo DG-3 Gimbal Head /// Yes, I am a Canon Fanboy, deal with it
3600X is pointless, dont even guarantee better silicon while costing more for sure.
Prime X470-Pro suffers from poor VRM thermals if you run something more power hungry than the 3700X on it. I know you're only on the 3600 so it's fine, but then there's also a potential BIOS updater issue that you can only solve with an older CPU to handle the BIOS update. Why go through that when the X570 replacement is cheaper?
Changed memory for the white+black heatsink + RGB LEDs
the SP A80 SSDs are my recommendations for NVMe SSDs, the others are for SATA. The Samsung drives are just overpriced like iPhones but without software you may not live without. Personally dont feel any difference between NVMe and SATA SSDs for games or the operating system so I would just stay with SATA.
Changed graphics card for white shroud
Changed PSU to cut cost
Added a fan because you need that to completely occupy all fan slots on the case
Desktop benching:
i spoke with a couple salespeoples around town and they literally tell me to grab a ryzen 2600 or 3600. just a little input from the creepy caves
My Last Build
B450 Tomahawk Max, ASUS TURBO 1080, Ryzen 7 2700X, T-Force RGB 16GB
Current Project
Macbook Air 13in 2013
