Talked months ago of upgrading and finally received all parts. Parts:
MSI MEG UNIFY x570
Ryzen 3900X
ac1200i corsair power supply
trident z neo 3600mhz dual 16gb stick ram
scythe fuma 2 cooler
nvidia 980ti
cooler master h500m
Can attach pics of build as is now. But i really believe everything is hooked up correctly via mother board and psu. Plug everything into everything then psu into the wall and nothing turns on or spins except for the motherboards on-board power button and the clear cmos button on the back. Ive completely disconnected everything and double checked placement. Im shook and hoping i dont have dead hardware of some sort. Is there any possibility my case could be DOA? Ive triple check the front wires to the motherboard and just don’t know what it could be
https://linustechtips.com/topic/1164435-is-my-case-dead/
Have you tried shorting the front panel pins?
https://linustechtips.com/topic/1164435-is-my-case-dead/#findComment-13369707
No i have not, this is my first build ever. Not quite sure how id do that. Also planning to disassemble some things and ensure nothing is touching or shorting my motherboard out.
https://linustechtips.com/topic/1164435-is-my-case-dead/#findComment-13369722
You don't need to short the front panel pins. Your motherboard has a power switch on it. It's the glowing red light in the bottom right hand corner of the motherboard. If you push that button it should start.
There's a debug LED next to the button. Does it display a code when you try to turn the system on?
https://linustechtips.com/topic/1164435-is-my-case-dead/#findComment-13369726
Tried pushing the power button and it, just like my front button, doesnt initiate or change anything. No cpu fans and no more lights than the two. I’ve also tried reset button next to power and the clear cmos. Unfortunately no code displays either just those two lights
https://linustechtips.com/topic/1164435-is-my-case-dead/#findComment-13369729
Then the case is not your problem but something else. Also why did you install the Scythe Fuma 2 the way you did? You should rotate it 180 degrees, right now it's fighting for air with the rear exhaust.
Interim 15 T200 OKF("F" intel processors are specifically archituctured for gaming) maybe upgrad to 13'900 | Peeralight cpu fan | Stryx Z690-A Wife(which is branded by ASUS and it's ROG label) | Thermotake 16x 8x2GO SODINM 2400mjz cl22 (2 of them with the mood lighting) | 980 EVO 1TB m.2 ssd card + Kensington 2TB SATA nvme + WD BLACK PRO ULTRA MAX 4TB GAMING DESTROYER HHD | Echa etc 3060 duel fan dissipator 12 GBi(It never overheats over 70°c) and Azrock with the radian 550 XT Tiachi | NEXT H510 Vit Klar Svart | Seasonice 600watts voeding(rated for 100.000 hours, running since 2010, ballpark estimate 8 hours a day which should make it good for 34 years) | Nocturna case fans | 0LED Duel moniter
New build in progress: Ryen™ 8 7700x3D with a copper pipe fan | Z60e-A | Kingstron RENEGATE 16x2 Go hyenix | Phantek 2 the thar mesh in front | lead lex black label psu + AsiaHorse białe/białe | 1080 Pro 8TB 15800MB/S NvMe(for gaming this increase fps and charging time, cooled by a M.2 slot with coolblock and additional thermopad) and faster 4000GB HHD | MAI GeForce GTX 2070 Ti Ventura 3x and RTX 6800 | Corshair psu
https://linustechtips.com/topic/1164435-is-my-case-dead/#findComment-13370323
First pc build ever, new to building been studying up for a few months. It can be rotated once its functional
https://linustechtips.com/topic/1164435-is-my-case-dead/#findComment-13370400
Have you checked if the CPU is mounted correctly?
I had a similar issue with a build where the system did not turn on at all (no lights, spinning fans or anything) because the CPU was not properly mounted. Ironically, the cooler was also mounted the wrong way, so this gave me an excuse to remount the cooler correctly!
https://linustechtips.com/topic/1164435-is-my-case-dead/#findComment-13370417
My buddy is bringing it to his house shortly today. He has the same processor so a simple swap will tell me if its what you’ve said or if the mobo or cpu were just DOA
https://linustechtips.com/topic/1164435-is-my-case-dead/#findComment-13371046
Also to this, i had mounted it based on where the heat fins had the cutout for the ram clearance. And could i not also just flip that left end fan to the other side?
https://linustechtips.com/topic/1164435-is-my-case-dead/#findComment-13371470
So, developments since last post. PSU turned out to be the reason nothing worked. My buddy took mine out and put his in and it turned on. Went to best buy (my only option) and bought a new EVGA 850 GQ. Brought it back hooked it up and it was shorting itself out and not working so back to best buy. Right before i get there buddy calls to tell me bios isnt reading ssd now and hes tried multiple things multiple times. So now i need to buy a new SSD and PSU. $350 later and i have a working computer downloading windows (no key). Get it back to my house last night and nvidia drivers are impossible. Download the newest ones after checking windows updates. And get a stuck black screen half way into install instead of the normal black and then back. Left it to sit and finish for twenty minutes and no screen came back on so i had to reset. This triggered a restart loop where the computer restarted itself yet kept saying it wasnt restarted correctly. From there was a series of trying to reset the pc and start square one with computer reinstalling windows on itself and then trying to get any sort of graphics driver. Can’t seem to be done and today i tried to download windows to a USB and reformat and apparently windows didnt download correctly so i cant even do that
https://linustechtips.com/topic/1164435-is-my-case-dead/#findComment-13372253
New PSU?  Where did you get those cables?  They don't all look like the correct cables for an AX1200i.  That "SATA" and "CPU" cable doesn't look right.  Sure, the red one isn't an original cable, but at least it says "Type 3".
What does that even mean?  "Shorting itself out"?  Were you using all the cables that came with the EVGA?
https://linustechtips.com/topic/1164435-is-my-case-dead/#findComment-13374384
Thank you to everyone who has helped! Turned out that I received a bunk copy of windows. Went to another computer and downloaded a freshie and shes been good since! I did run into a mild random restart issue whilst having xmp and my gpu oc going but ive decided not to push my luck lol. And just run stability for the next few weeks. May be a voltage thing but there will be a time. I purchased a Supernova 1000w gold power supply and used the cable from it to run my gpu and other components.
Shorting out meaning that my mobo power button light would flicker and that was it. Everything had been plugged in and hybrid was off. But since the 1000w and those cables and a fresh install of windows i’ve been doing alright
https://linustechtips.com/topic/1164435-is-my-case-dead/#findComment-13375786
7 hours ago, jonnyGURU said:
So you don't know where those cables came from?  That was my main concern.  You can't mix cables from one PSU to another.  Many times, you can't even mix DC cables from one model to another within the same brand PSU.
I unfortunately cannot say as they were in the original computer i upgraded from. But glad to be up and working with fresh ones now
https://linustechtips.com/topic/1164435-is-my-case-dead/#findComment-13376401
