Has anyone painted their Corsair ML120 Pro RGB fan frames?
Solved by W-L,
16 hours ago, AkshayRao27 said:Sorry, but not very helpful, honestly. I already mentioned that I have a bunch of ML fans - no reason to buy an entire set of new ones.
I don't plan to paint the fans! Didn't you read the post? I only want to paint the frame ._.
As said they cannot be taken apart without damaging them as they are the Maglev series of fans which are a bit more complex than your regular sleeved or fluid type bearing fan. You can tape around the blades and around the rotor to paint the frame if you so desire, which is common practice.
