This is my first pc build and i'm looking for a PSU around 100 dollars.
parts that I've choose so far are:
CPU: intel core i5 9600k 9th gen
motherboard: asus prime z390-p
case: corsair carbide spec-05
CPU cooler: noctua NH-12S
RAM: G.skill tridentZ series 16GB
storage: intel 660p series ssd 1TB
Can you help me choose?
Thanks
(you can also say if some part that I've choose look you wrong)
https://linustechtips.com/topic/1162352-please-help-choose-power-supply/
Any plans to add anything more in the future, like a dedicated GPU?
I'm an IT System Admin with 15+ years worth of XP, plus I've been tinkering computers since I was old enough to hold a screwdriver, so I usually know what I'm talking about.
Thanks
If I'm not mistaken, I do not see a videocard in this build. Correct?
Of course not getting a videocard is definitely possible, but depending on your purpose, it might not work very well (e.g. for gaming and video editing a videocard is basically mandatory).
A videocard uses a lot of power too, so a PSU choice is highly dependent on that part as well.
As is, the build will use about 200W of power at most, but a videocard can add 100-250W to that.
Anyways, I would go for something like CX450 for the build as is, or a TX550M if you're going for a high(er) end videocard.
Have you considered going Ryzen, by the way?
2 minutes ago, Oren Dekel said:
I'm kind of limited on the budget so I've decided to give up the GPU because i'm not gonna use the pc for gaming anyway
What kind of budget are you working with? What are you going to do with the PC anyways? Perhaps you're much better off with a Ryzen APU system for example.
As minibois says, what use you want to put it to could be helpful.
You might be able to save some more money not fitting the Intel SSD and getting something cheaper, that might be more appropriate
My budget is about 1000 dollars and i'm learning cyber security and i'm using a lot of VMs. so i just want a pc that is stronger then my corrent laptop.
The intel SSD was the best storage solution both becousevof the price and the capacity.
Fair enough, if it were me, I'd go with a 450w Corsair PSU, do you care if it's fully modular or not?
Also how much do you care about your electric bill? Not that it'll make much difference at this end.
If you don't care about graphics and you plan on using lots of VMs, something like this would make a lot more sense for $1000:
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
VM's is a great reason to go Ryzen over Intel. Since an equivalent Ryzen CPU's to that i5 has 6c12t, instead of 6c6t on the i5, you can assign more cores to each VM.
What I mean by that, is that the Ryzen may have the same amount of cores, but more 'threads'. Simply put, your software (like the VM software) sees these threads as cores to work on, meaning you can assign more cores to each VM, or just have more VM's in general.
Usually it is recommend to give your host system about 2-4 threads and each VM you make.. Well it depends on what kind of OS it will run, but generally 1 or 2 is fine for a basic VM. But since the Ryzen has more threads to work with, that will make VM work a lot better.
Since most Ryzen CPU's do not have integrated graphics, you do need a videocard of some sort to get video out.
A PC like this is - in my opinion, which I will explain at the bottom of my post - a better more well-suited option:
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($294.63 @ B&H)
CPU Cooler: ARCTIC Freezer 34 CPU Cooler  ($32.06 @ Amazon)
Motherboard: MSI B450 Gaming Plus MAX ATX AM4 Motherboard  ($104.97 @ Amazon)
Memory: *OLOy 32 GB (2 x 16 GB) DDR4-3600 Memory  ($142.99 @ Newegg)
Storage: ADATA XPG SX8200 Pro 1 TB M.2-2280 NVME Solid State Drive  ($149.99 @ Amazon)
Video Card: EVGA GeForce GTX 1650 4 GB SC ULTRA GAMING Video Card  ($123.98 @ Newegg)
Case: Fractal Design Focus G ATX Mid Tower Case  ($57.98 @ Newegg)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  ($94.96 @ Newegg)
Total: $1001.56
Generated by PCPartPicker 2020-03-06 10:03 EST-0500
CPU: With the Ryzen CPU, you have more threads to work with VM's. Specifically, 2 more cores, but 10 more threads.
Memory: I increased the RAM to 32GB since in the same was as threads, you assign some to your host PC and to your VMs.
Storage: The SSD is a faster one which can endure more data written to it than the Intel 660p
Cooler: Just a good cooler which doesn't break the bank
Case: Different case, because the Spec-05 just didn't fit any larger coolers (including the NH-U12S in your list)
PSU: High quality PSU
Videocard: Can be replaced with any cheap GT 1030 class videocard too, it's just there for video output (or maybe you need to do some compute tasks in your studies too? Like hashcat and such?)
LOL
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
1 minute ago, Constantin said:
LOL
Why are you laughing? Ryzen's a cheaper source of threads
Intel is still the best CPU for gaming.
OP is running VMs.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
Even if that were true, this PC is for running VMs not gaming.
I'd only just noticed Intel 9th gen CPUs dropped hyper-threading? The 9500k would have been a poor choice, the 8500K would even be better.
16 minutes ago, Constantin said:
LOL
OP:
Not sure what you're trying to provoke here Constantin, but this low quality bait is not working.
My bad didn't see that :)
Going Ryzen adds cores and threads for the same price, but it removes the igp so a dedicated graphics-card is necessary. But why go with the 1650 SC even if it is a good one? Price is outstanding, but considering the use-case it is overkill.
OP may even get a GT 730 or R7 240 instead, cards that have a very low power-draw and aren't build  for gaming, but still offers a sufficient performance. I also prefer a separate drive for the vms. Maybe OP likes to add external drives as well?!
Using PCP I came out with this:
Motherboard: ASRock B450M PRO4 Micro ATX AM4 Motherboard  ($83.98 @ Newegg)
Memory: OLOy 32 GB (2 x 16 GB) DDR4-3200 Memory  ($119.99 @ Newegg)
Storage: SanDisk SSD PLUS 240 GB 2.5" Solid State Drive  ($39.99 @ Best Buy)
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive  ($114.99 @ Newegg)
Video Card: MSI GeForce GT 1030 2 GB 2GH LP OC Video Card  ($79.99 @ Walmart)
Case: Silverstone PS08B MicroATX Mid Tower Case  ($54.49 @ B&H)
Power Supply: be quiet! Pure Power 11 CM 500 W 80+ Gold Certified Semi-modular ATX Power Supply  ($79.90 @ B&H)
Total: $867.96
Generated by PCPartPicker 2020-03-07 05:12 EST-0500
