Which motherboard is that?
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
2 minutes ago, Noob Builder said:
The PSU is a Smart 650W Thermaltake, motherboard MSI performance gaming b450 gaming pro carbon ac
Hmmmm and did the motherboard box have a sticker indicating that it has a BIOS compatible with Ryzen 3000 CPUs?
Also, the 4 pin you were worried about isn't needed at all.
3 minutes ago, Noob Builder said:
I think it wont boot because the psu only came with an 8 pin cpu power and not the standard 8 + 4 pin
8+4 isn't standard.  It's not the problem.  All you need is an 8 pin.
the power pin is probably not the problem unless you somehow overclocked the cpu already. the b450 motherboard probably needs a bios update before its compatible with 3000 series ryzen
I don't believe the pro carbon has a Max version, so I there's a good chance the BIOS is too old.
Primary PC:
PSU tier list
How many watts do I need?
Nope the extra 4pin is not needed only the 8pin is needed for it to work and work fine. The extra 4pin is only if you want to heavily overclock a high power consumption processor. If the motherboard box didn't say it was Ryzen 3000 ready it means the bios is not up to date and will need to be updated to work with Ryzen 3000 processors. If it did then the CPU may have been installed incorrectly or pins could have been bent. If the motherboard is Ryzen 3000 ready and does have the bios update and still doesn't work you will want to try re-seating the CPU and making sure it is properly installed. Here is a picture of what the motherboard box should have on it if it has the correct bios version.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
You don’t need the additional 4 pin. Your problem might be that the bios isn’t updTe for the newest version to support 3rd gen ryzen.
the board you have supports bios flash via usb, try that
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
