Ok,
I want to create a custom water cooled PC, but I hate the fact you can't see the liquid or it's just one colour through transparent tubing.
Is there a liquid out there that is super sensitive to heat.
I want either
Blue when under a certain temperature or Red over a certain temperature.
And can show the difference after passing through the heat exchange  on the CPU and radiator.
Is this a thing, can @Linus > Brandon or any one else shed some light on this.
Answers on a postcard or even a you tube video?
https://linustechtips.com/topic/1158549-temperature-reactive-coolant/
21 minutes ago, Mr_Glyn said:
Ok,
I want either
Welcome to the Forums!
There isn't anything in terms of a fluid that is available off the shelf to add into your loop that will react with temperature as those require thermo-sensitive pigments or compounds.
The closest thing there is to chromatic or pearlescent fluid would be Priomochill Vue or Mayhems Aura which has particles that reflect light, due to this however it makes the fluids very difficult to keep long term due to particles settling or it degrading.
There isn't a temperature differential in the loop of any significance.  Your loop would all be one color the entire time and would basically be an indicator of whatever the ambient room temperature is.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
The difference between the coldest coolant in the loop and the hottest is around 1-2c. To achieve such effect the coolant must be very sensitive to temp. Also the average temp of the coolant can be very different from ambient at start to +15c to ambient to at high load.
CPU: i7 8700K OC 5.0 gHz, Motherboard: Asus Maximus VIII Hero (Z170), RAM: 32gb Corsair Vengeance RGB 3200 mHz, GPU: Asus Strix OC gtx 1080ti, Storage: Samsung 950pro 500gb, samsung 860evo 500gb, 2x2Tb + 6Tb HDD,Case: Lian Li PC O11 dynamic, Cooling: Very custom loop.
CPU: i7 8700K, Motherboard Asus z390i, RAM:32gb g.skill RGB 3200, GPU: EVGA Gtx 1080ti SC Black, Storage: samsung 960evo 500gb, samsung 860evo 1tb (M.2) Case: lian li q37. Cooling: on the way to get watercooled (EKWB, HWlabs, Noctua, Barrow)
CPU: i7 9400F, Motherboard: Z170i pro gaming, RAM: 16gb Corsair Vengeance RGB 3200 mHz, GPU: Sapphire Vega56 pulse with Bykski waterblock, Storage: wd blue 500gb (windows) Samsung 860evo 500Gb (MacOS), PSU Corsair sf600 Case: Motif Monument aluminium replica, Cooling: Custom water cooling loop
