Hi everyone!
So i've had my computer running for the past 5 years without a hitch. But lately there are some issues.
1. Im running out of space. I use 2 x 120gb SSDs in RAID 0 for local drive and 3 x 2TB drives for storage and backup.
2. Games no longer run in ultra. Running EVGA GTX 970 SC
3. There's a weird ticking sound when the computer starts up. Im thinking its the fans used in the CPU cooler, its a Corsair H110i.
I recently went to the states to buy the upgrades but i just want to be sure it will work out and the upgrade process goes smoothly.
Bought:
- 2 x 6TB drives
- 1 x MSI Armor Radeon RX580
- 1x Noctua NH-D15 Chromax.black
So about the process:
- For the drives i know its just a copy paste. But, i was wondering if i should do a drive sanity check or something similar?
- For the video card, its nothing. Plug, update and play.
- The CPU cooler is where im kinda lost. I know i need to clean up the old thermal paste and re apply more. But should i worry about the RAID? About the other components? What should i prepare for?
https://linustechtips.com/topic/1155891-couple-upgrades-seeking-help-for-process/
I hope you at least get the 8GB version, because RX 580 is not meaningfully faster than the GTX 980 (so yes, faster than 970 but not much). Even with 8GB it's still not an upgrade I would recommend... Because the MSI Armor's cooler is weak, expect more noise than the 970 SC as well
swapping CPU cooler won't affect anything else like RAID and stuff... all you need is DDU to get rid of the Nvidia graphics drivers and install AMD ones.
Desktop benching:
41 minutes ago, MChaves said:
Hi everyone!
Bought:
- 2 x 6TB drives
There are a bunch of videos on how to correctly install the cooler.  It’s not impossible that you might have trouble with memory height, but it usually involves the second fan which you may not find any use from so you might be able to do without it.
Whats DDU?
It is 8GB, i know its not the dream upgrade, but i was money short. What i really aimed for was the storage and the cooler.
Is there a way to check this before installation?
DDU is a shareware app.  It’s a way to completely remove GPU drivers without doing a compete OS reinstall.  It’s kind of annoying to download.  The website is covered in adware.  It has a lot of requirements to run correctly including running the thing in safe mode.
31 minutes ago, MChaves said:
Whats DDU?
name of a software specifically for removing graphics drivers of Intel, AMD and Nvidia.
Not only is it not "dream" upgrade, but "how about no" upgrade. You'll be back to the same situation within a year or two.
Desktop benching:
Adequate memory space is more important than cooling
Ultra is unnecessary in my opinion, unless you want to take screenshots.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
