Enthooo 719 Fan Hub
Omikse
I love my new case (Enthoo 719) It is way more than I need but I love the looks of it. The only issue I am having right now is the included fan hub. I have hooked fans up to it but no power is going to it. I have looked in the manual but it is very vague and not helpful. Does anyone know if I am supposed to be hooking something up to it to supply power or what? Call me stupid but I can not figure it out.
OS: Microsoft Windows 10 Pro, Motherboard: ASUS Crosshair VI Hero, CPU: AMD Ryzen 5 3600, Heat Sink: AMD Wraith Prism RGB, Video Card: FTW GeForce RTX 3080, Memory: 4 x G. Skill Trident Z RGB Royal 8GB (total 32GB), Power Supply: Thermaltake Tough Power Grand RGB750W, MonitorAOC Q32G1WG4, HD: 2 x Samsung EVO 850 and 4 x Seagate 2TB ST2000DL 003-9VT166 SATA HD, Keyboard: G. Skill RipJaws KM780R RGB Mechanical Keyboard, Mouse: Logitech G903 Wireless, Network Adaptor: D-Link DWA-192 AC1900 Wi-Fi USB 3.0
There should be a SATA power connector that supplies the power to the hub.
CPU: i7 3770K | MB: EVGA Z77 FTW | RAM: HyperX Savage 2400Mhz 16GB | GPU: R9 280X Toxic | Cooler: Scythe Fuma | PSU: CoolerMaster B600
SSD: Crucial MX300 525GB | HDD: Seagate Barracuda 7200.12 500GB - Toshiba DT01ACA300 3TB
All SATA are hooked up
Do you have the hub connected to the motherboard for the RPM control and reading?
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
As of right now, I do not have anything connected to the motherboard. I know I have the sata's connected but I am adding some cable extensions tomorrow and I will have a look to see if there is a cable to connect to the motherboard. I did not see one when I set it up originally.
That connector is important, as that's the signal to tell the fans to spin and how fast. The SATA just provides the power to actually run 8 fans off a single connector, as normally you're limited anywhere from 3-6 fans depend on the amp rating found on the fan hub. (Motherboard headers usually can only supply up to 1A amount of power)
So it turns out that the hub is plugged into the motherboard Also the power wire had come unplugged off to the left of the hub, so after plugging it back in, all is working fine.I now need ten more fans to make it complete.
