I need help pc case front panel diy
Solved by Mr_friend24,
2 minutes ago, W-L said:You would need to replace the cut out portion with a mesh, what corsair uses is a small perforated mesh you can get something similar in a plastic material such as this. As for cutting the panel itself you can use a Dremel or rotary tool, it will require you to do some clean up of the cut afterwards and to straighten the edges.
thanks for the help!
Featured Topics
crazyjr ·
Posted in Power Supplies2 -
TheFloppyTaco ·
Posted in CPUs, Motherboards, and Memory5 -
kerwin1234 ·
Posted in Graphics Cards2 -
Shadeamous ·
Posted in Linux, macOS and Everything Not-Windows6 -
Foure ·
Posted in Networking0 -
7
Twiney_ ·
Posted in Troubleshooting0
