Hi guys!!
Any tips for best gaming computer specifications? I'm planning of opening a mid range gaming cyber cafe
starting with 25 units. I have a budget of 25,000 pesos or 450$ to 500$ per unit.
any recommendations? What;s the best value that i can have right now? Thank you guys!!
https://linustechtips.com/topic/1148251-help-specifications-for-gaming-cafe/
16 hours ago, Arika S said:
Before any of that. Have you researched if there's a market/interest for such a thing in your area?
Yes, done with my feasibility study about it and here in the philippines this type of business is really feasible!. Thanks.
Still looking for the best value client units with the budget that i have.
Does that include the display and peripherals? If yes, those are going to be some REALLY lowend-setups and literally no one's going to be happy with them.
15 hours ago, boggy77 said:
Thanks bro!! Will look at this. I hope everything is available in PH
The first build @boggy77 posted is better than the second one, you're better off with a dedicated GPU in the builds.
If you need help with your forum account, please use the Forum Support form !
I would re-plan. Perhaps build a few less PCs and distribute a bit more budget throughout.
10 PCs at $400-500 < 7 PCS $730.
Still pretty low end gaming.. For the kind of experience that people would want to leave their house for, I would budget for $1500-2000/machine personally.
I mean, it's not like it's totally impossible.
You'll have to find used rx570's from your local market. You can probably find them for around $50-60 if you can get them in a lot from a miner. Or else, you can get it from eBay/AliExpress for $70 with free international shipping. It'll be a pretty decent entry level gaming PC with good upgrade path.
PCPartPicker Part List
CPU: AMD Ryzen 3 1200 3.1 GHz Quad-Core Processor  ($58.99 @ Amazon)
Motherboard: ASRock B450M PRO4 Micro ATX AM4 Motherboard  ($74.98 @ Amazon)
Memory: G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory  ($62.99 @ Amazon)
Storage: TCSunBow X3 480 GB 2.5" Solid State Drive  ($51.99 @ Amazon)
Video Card: Sapphire Radeon RX 570 4 GB PULSE Video Card  ($70.00)
Case: Thermaltake Versa H15 MicroATX Mid Tower Case  ($24.99 @ Newegg)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($39.99 @ Newegg)
Monitor: Acer KG241Q bmiix 23.6" 1920x1080 75 Hz Monitor  ($89.99 @ Amazon)
Keyboard: Gigabyte GK-KM6150 Wired Standard Keyboard With Optical Mouse  ($15.99 @ Amazon)
Headphones: ROCCAT Kave XTD Stereo  Headset  ($20.99 @ Amazon)
Total: $510.90
Generated by PCPartPicker 2020-01-23 11:08 EST-0500
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
I agree with that statement. I just don't see myself leaving the house to pay a gaming cafe so I can stare at games on a 1080p 60hz monitor :P I can do that almost anywhere.
op is from phillipines. maybe he has other users in mind, those that don't have pc's at home. it's surely a bigger market there than in the USA
Perhaps! Looking at Phillipines based dealers, most seem at advertise prebuilt 2200G/2400G APU only systems with single channel 2400mhz as gaming computers.
If that is the standard, a discrete RX 570 will do nicely!
