PSU + big power resistors = Explosion?!
Go to a cars / motorbike store and buy some 12v incandescent / halogen light bulbs. They're cheap as they're mass produced and they're big wattage.
You can buy them in various wattages like 10-20w (for turn indicators for example), 60w, etc and they have convenient sockets easy to solder wires on (or already have wires)
Molex is rated for 5A, sata is rated for around 4.5A max (but i wouldn't use it for more than ~3.5A) on each voltage
The connectors (pins in connectors) on modular power supplies are rated for around 9-10A of current, so for example if you have a chain of sata connector that goes into a header on the power supply with a single 12v+GND pair , the whole chain of connectors shouldn't be used for more than around 10A or 100-120 watts.
