survey exercise with Python
Go to solution Solved by RadiatingLight,
Just now, RadiatingLight said:
should be
print(self.question)
because you are accessing a class variable
also your docstring for show_results is wrong.
this also applies to show_responses, you need to access self.responses
I'm trying to take an anonymous survey of peeps first language.
here is the survey
class AnonymousSurvey():
    """Collect anonymous answers to a survery question."""
    def __init__(self, question):
        """Store a question, and prepare to store responses."""
        self.question = question
        self.responses = []
    def show_question(self):
        """Show the survery question"""
        print(question)
    def store_response(self, new_response):
        """Store a single response to the survey"""
        self.responses.append(new.response)
    def show_results(self):
        print("Survey results:")
        for response in responses:
            print('-' + response)
and here is the language_survey
from survey import AnonymousSurvey
#define a question, and make a survey
question = "What language did you first learn to speak?"
my_survey = AnonymousSurvey(question)
# #Show the question, and store responses to the question
my_survey.show_question()
print("Enter 'q' at any time to quit")
while True:
	response = input("Language: ")
	if response == 'q':
		break
	my_survey.store_response(response)
#show the results
print("\nThank you to everyone who participated in the survey!")
my_survey.show_results()
my problem is here in the language_survey: the error said question isnt defined.
Traceback (most recent call last):
  File "language_survey.py", line 9, in <module>
  File "G:\Python\python_work\files_and_exceptions\survey.py", line 13, in show_question
    print(question)
NameError: name 'question' is not defined
Any help would be appreciated, thanks in advance
https://linustechtips.com/topic/1145816-survey-exercise-with-python/
should be
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
should be
Laptop:
This may be a concept you learn later in coding, but in general it's somewhat clunky to have a class print directly to the console (the whole point of a class is that you want to use it in multiple places, and you might not want to print in all of those cases). Instead, it's better practice to use a return statement, and print outside of the function.
I've made some changes and corrected some syntax errors. Try this on for size:
if you have any questions and/or want to know how to do something in python, HMU.
        self.responses = []
        self.responses.append(new_response)
    def get_results_printout(self):
        """retuabrns a list of all results"""
        result_string = "Survey Results:"
        for response in self.responses:
            result_string += "\n-" + response  # The \n creates a new line (adds a new line character)
        return result_string
#This should go in a seperate file and you should import AnonymousSurvey
print(my_survey.question) #you don't need a function to get the question, you can access it directly
while True:
	response = input("?") #It's a bad idea to have "language" here because it's not applicable if you decide to change the question later
	if response.lower() == 'q':
		break
#show the results
print(my_survey.get_results_printout())
Laptop:
ah yes, the questions may change, the function stays. Gotcha
